Don't do that - get a price for splitting the tails and going via a switchfuse to the garage - there are nothing but disadvantages with supplying via the house CU.I'm going to get a price for a seperate 63A feed from the house CU, through the lounge celing cavity and out to the garage CU. Looks like I will be needing 16sqmm so pretty hefty stuff.
Apart from that, it's perfect.When I finally had my 'boiler upgrade' they reckoned my HW cylinder was knackered and replaced it. It came with an integral immersion heater and I noticed that the installer had fitted it with a 13A plug and had run a spur from the upstairs ring into the airing cupboard. This ring supplies gadgets like a couple of computers, radios etc. I have a Building Works compliance certificate to cover the whole job. I have put the plug into one of those plug-in RCDs for added safety as my CU needs upgrading eventually when I have the dosh. I did ask the Gas Safety inspector about this arrangement (he came as part of their regular checks on gas installers and found the boiler job to be a good one). As for the electrics to the immersion, he said that he could only report on the gas side of things but we 'have to live in the real world' and to run a separate connection to the airing cupboard would add hundreds to the bill - my setup was by far the most usual in his experience, even if technically against the regs.
What a stupid thing to say.WhatHe said that most immersion heaters only heat part of the cylinder water - is that right?
I'm guessing you haven't heard of stratification.What a stupid thing to say.WhatHe said that most immersion heaters only heat part of the cylinder water - is that right?
