Wouldn't mind knowing where these controls can be had for such a good price.
Tks in advance
Tks in advance
it says 418 in the OP!
You can't set the D numbers for max output on the new model, it is disabled and unnecessary due to the wider mod ratio on the boiler.
although lowering the temperature of the primaries in hot water mode must have the same effect as lowering the kws...
The Op is over a year old kevin.
scoobydo123 said:Wouldn't mind knowing where these controls can be had for such a good price.
I am merely questioning why you can no longer alter the kw output of hot water mode...its very useful...I bet you can still alter the temperature though (also very useful)..
Vaillant must have seen the advice, given many times on this forum, to adjust d.0 parameter to provide the correct heating output, and decided to automate this.I expect its been disabled due to this new feature:
"Self adjusting range rating function which learns the maximum heating requirement of the system without the need for setting, ensuring the most efficient mode of operation"
Lets hope that it ranges up towards Max that the installation can take at the time rather than start at x of maximum rating of boiler then cycle down. That way if a flow temp of 40c is requested by external controls it wont reach and overshoot target and get in a cycling loop![]()
Up grade me on your experience with the 418, vr65 and vr 362 or 470 would you install this for a client...
I am being asked to quote to install an OV boiler...are these components a happy mix?
this new feature is very clever, it will automatically adjust up and down several times per week!
