Between my neighbours house and mine there is a double width driveway, (ie our drives are side by side), and the boilers in each house have the flue discharge from the boiler in the kitchen through the wall to outside and over the drive ways at approximately thigh height;
Unforunately this has already damaged the paintwork on one car, presumably from the constant barrage of hot boiler exhaust being blown at it.
When my neighbours had their boiler replaced by BG a year or so again they were advised to have a 'chimney' fitted to raise the flue exit point;
This seems like a good idea and I wondered if it would be possible to do anything similar with my outlet?
If so is it relatively straighforward to do?
Would I be 'allowed' to do, or does it need to be done by 'GasSafe'?
Also I'm presuming it is a specific type of pipework, not your bog standard B&Q plastic piping?
Where do I start to look into having this done?
Thanks!
Thanks!
