Hi all,
I didnt want to resurect an old thread but i'll ref here if thats ok:
Basically, thats the same symptoms im facing just now with the same boiler. I've opened the front of the pump and the screw moves when I turn it but doesnt budge when I run the DHW. Water coming out is clear but was initially dirty. I just get lots of banging, pressure through the roof and steam via AAV.
Im looking to see if someone could help me with removing the head to have a look and see if there is anything blocked in it? Would call someone in but broke as hell just now. Only in this house circa 6 months and just replaced two joists in the bathroom due to leaking shower base
, the boiler is now on the blink and......workman just chapped my door to let me know they need to dig up my garden to replace a small sub station outside. The later wont cost me anything but letting you know where my life is at right now
Im handy enough and have searched this but few points I wasnt sure on.
The manual states to shut off flow/return valves and drain using taps under the boiler but others have said not to close these as they might leak when I open them?
My Plan is.....
1). Isolate power
2). Do I need to close main water in?
3). Open taps under boiler and drain boiler.
4). Remove 4 allen screws on pump and remove.(I'll Post pics if anyone could see anything wrong with it?)
5). Screw pump back on.
6). Fill system back up with taps open? Close when water comes through?
7). Leave from of pump open until water comes through then close?
8 Fill to cira 1 bar.
I know this maybe be elementary but i've got a cold house, a wife and 2 kids and we all need showers. If I could get some help i'd appreciate it. I know this may not be amatuer hour but im over a barrel here.
Thanks.
RK
http://www.diynot.com/forums/viewtopic.php?p=68502#68502
My Plan is.....
1). Isolate power
Thanks.
RK
