- Joined
- 27 Jan 2008
- Messages
- 29,235
- Reaction score
- 3,586
- Location
- Country
To draw 40A at 230v 3 phase is really some massive motor.
With single phase the motor has to have a helping hand. Be it a capacitor, centrifugal switch, timer, together with start and run windings one way or another we have to get it turning with most squirrel cage motors.
With three phase we have the reverse problem we need in some way to reduce the current used at start be it an electronic soft start or resistor, auto transformer or star delta.
The inverter allows us to use three phase motors on a single phase supply and control the ramp up and down to within limits never before through possible with a squirrel cage motor.
However with a compressor it all to do with the matching of de-load with the motor start. Three phase is easy as the motor goes into delta so we drop the de-load. However with other types of starting the matching can be a problem.
I remember one compressor which would regularly blow fuses having us all scratching our heads as to why as there seemed to be no electrical fault. In fact in the end it proved to be a mechanical fault the outlet valve was leaking just slightly and pressurising the cylinder once this had happened there was not enough pressure to lift the inlet valve to de-load. As a result of trying to start under load the fuse would blow.
It was cured by instead of lifting valve in star it was dropped in delta so when not running inlet valve always open so pressure could not build up.
Faults like this are hard to find and it needs someone with both mechanical and electrical knowledge to cure.
I will guess it's the start amps rather than run which is causing the problem here. And rather than a larger supply what is required is some other way to start it.
With the fault I related it would start and run OK with empty tank it was only as the pressure increased and a re-start with pressure already in the tank was required that the problem arose.
Now it may be for things like paint spraying it is just a case of setting the pressure to a lower value. But since we don't know what the compressor is like it's all guess work.
But I can see no reason for the way the query was answered. The idea is to say how he can get around a problem not just say you can't do it that way.
