OP are you saying that you have a THERMOMETER attached to your cylinder that reads in your bathroom? There is a difference between a thermometer and a thermostat
It is a thermostat that tells me the temperature of the water inside the cylinder. It is used to set the max temp of the water heating and is connected to the motorised valve, so when temp is reached, the boiler switches off. I can also use it to guage the water temp, e.g. turn it down a bit until the "reached" red light comes on indicating cylinder temp
Right, so it doesn't tell you the temperature, you set the required temperature, the heating warms the water until it reaches its set point... You just flick it up and down to estimate at what temperature your water is by means of the red light..... And this non IP rated thermostat is in your bathroom... Yes?
That's correct, it doesn't actually give me an accurate reading but a good idea of whether or not ther is enough water in the tank for a shower without having to put the heating on, or if it hasn't reached, knowing that i have to wait a bit longer for the shower. My solar control however, tells me exactly how hot the water is, so tend to use this if I need an exact temp reading.
