- Joined
- 2 Oct 2010
- Messages
- 3,624
- Reaction score
- 667
- Country
I guess the op has been touching himself up. His own profits that is.
Like most people I don't like being ripped-off by Trades-people who assume that their clients are naive or thick, which is what's happened to me many times in the past with Kitchen Appliances and Car-Servicing / Repairs.I guess the op has been touching himself up. His own profits that is.
You appear to have edited your post regarding working on your neighbour's boiler?
You have to remove the front panel (two screws) but you do not have to access the Combustion chamber to replace the poor quality 'red lead', or to change the igniter, as that can be done from below the Combustion Chamber.That's a pretty neat trick not taking off the front cover to replace the HT lead
They will also be informed about the 'red lead' fault, which does not require access to the Combustion Chamber.
If what I've done is 'illeagle' (sic) then so be it.
Not £350, which is what Potterton were going to charge me.What is a reasonable profit percentage for an independent boiler repair company to make?
The manual supplied by Potterton refers to the part which I removed as the "Front Case".awowen said:Please could someone enlighten the Op (about the Combustion Chamber).
