I am ready to lay the DPC before building my walls up. I have laid the blocks work up to DPC and installed the concrete slab. The slab DPM over laps the wall. Questions are
a) should the DPM be fitted above or below the DPC roll?
b) should there be mortar, below, between, and above each layer? eg 10mm mortar, DPM, 10mm mortar, DPC, 10mm mortar, block? If not, how should it be done.
