You are aware that filming public on the paths and highways isn't allowed?
The camera can only be position to cover your property, garden, drive way. Something to do with human rights and privacy.
As for off topic, that is a bit rude of you to say so. All I was trying to suggest is that the position of the recorder could be anywhere if the real time events that are recorded can be off site stored in real time.
As already mentioned, CCTV is seen and if someone does do the dirty and breaks in surely the comfort of knowing that even if they steal or break the unit it doesn't matter since the recordings are held off site.
Framing rate adjustment, compression and active only on sense make that do able.
You seem fixed in your ways so you must know best
