Hello,
I am going to get a double oven in place of a single oven aswell as replace an electric hob.
The double oven instructions (dled) recommend either a min rated 32A double pole switch(lol which i cant find anyway) or if with a hob ,a 45A double pole switch. To quote "a 45A Double Pole control switch should be used to feed both units via seperate suitably rated cables."
Now firstly i cannot see under the hob but i can see the old single oven goes to a conventional mains double socket. The single oven has a standard 13a plug attached. The mains socket has 2 wires wired into it. I am assuming like a dp switch they are the feed and maybe the load from the hob as i cannot see anywhere else the hob could possibly be connected to.
I have a few questions. I am interested in electrics and would like to be in the know. 1. am i likely to be correct in assuming it is the hob load? 2. If its the case, would the hob be wired to one of the plug spaces and is it safe? 3. Do they make double dp switch boxes with 1 feed or would i need 2 seperate boxes and if that the case would i need to have wire to consumer box rewired as there seems to be only 1 feed? 4. Do i even need dp control switches- can i just have done like has been done allready or something similar but with the Double oven hard wired and a suitable fuse at the consumer unit?
Thanks for any help
Thanks for any help
