Ok firstly let me start by saying i'm an enthusastic DIYer and not a plumber so please keep it simple.
I've taken the radiator off in my bathroom and want to swap it for one of these towel radiators. The towel radiator is slimmer by about 15cm so i need to bring the pipes in and turn the valves into inline rather than side fed. All of this I think i could do if i could turn the water off in the appropriate place however my issue is i don't know how. The water is currently sealed by the inlet and outlet valves so if i took them off to replace them i'd get drowned and empty the system (combi boiler system).
I'm guessing i could turn the water off at the mains and drain the inlet which would stop the inlet valve flow. Could i turn the next radiator off in series and then drain that down to seal the other end? or am i going about the process completely wrong and need to seal the system.
I'm basically seeing if i can do this myself rather than pay a plumber - which i'm expecting to cost me circa £200 (any ideas).
Thanks in anticipation of your replies!!
