how does the hot water flow in the towel radiator ?
20 Mar 2008
Devon
could you please tell me how to plumb in a towel radiator off the hot water system. Do I need to feed a designated supply from the outlet and inlet of the cyclinder?.
HI
sorry but you cannot plumb a towel radiator off Hot Water system it has
to be from central heating pipes.
Question - If you want to have a towel radiator on when the heating is off but the hot water is on i.e in our great summers! do I have this bitis bit right?. I can see that you would take the feed from the point between the pump and the motorised valve, but whats the best area to return the flow?
HI
can you really plumb into HOT WATER outlet from the cylinder ?
draw off?
to the cylinder return
