Hi. I am wiring an immersion heater to be used in conjuction with a solar cylinder (i.e. to supplement the solar thermal panels when necessary).
There is a fused spur and I propose to take the wiring to a time clock (which I assume wires just like a switch) and then to a thermostat - to switch the immersion ON when the temperature is low enough (wiring it so that set temperature CLOSES the circuit). Presumably, the immersion heater itself will switch off when target temperature is reached.
I'd be most grateful if someone could confirm, or otherwise, that what I am proposing is correct.
Thank you!
Thank you!
