    Dismiss Notice
New immersion heater still tripping RCD
Discussion in 'Electrics UK' started by Iain Milligan, 15 Feb 2020.
  1. Iain Milligan
    Iain Milligan
    15 Feb 2020
    Thanks Received:
    Country:
    We don't generally use the immersion heater so I'm planning to wire it into a Solic 200.
    First - to make sure it is working I removed the old time clock and controlled it direct from the 16A MCB switched spur - 80A RCD tripped.
    Isolated the tripping to the immersion heater, as wiring a light into the switched spur caused no tripping.
    Today replaced the immersion heater with a new Tesla 3KW and new 32A wire - still tripping the RCD. Measured 19.4 ohms across the element with no measurable leakage to earth or the plumbing.
    In fact it is only when the element is powered it trips. When the temp switch is low 20deg C - i.e. element switch off it is fine and power being on does not trip it.
    Any thoughts - RCD faulty? - 16A MCB too low powered?
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    63,853
    Thanks Received:
    3,375
    Gosport
    Country:
    Cook Islands
    show us photos of the cables and the wiring, please.
    Try connecting a kettle to the same circuit. The load will be about the same.
  4. EFLImpudence
    EFLImpudence
    7 Jul 2010
    32,198
    Thanks Received:
    3,492
    Retired to:
    Country:
    Portugal
    What is a 16A MCB switched spur?
    30mA/O.03A RCD tripped.
    Ok. Something to do with the immersion and/or its wiring.
    3kW @ 240V is 12.5A.
    Should be alright then.
    Instantly or after a while when hot?
    Not impossible.
    Nothing to do with it.
  5. RF Lighting
    RF Lighting
    31 Mar 2006
    19,292
    Thanks Received:
    1,248
    Leeds
    Country:
    It is not connected correctly
  6. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    2,972
    Thanks Received:
    567
    Durham
    Country:
    What else is protected by the RCD? Pics of the connections? What did you test with- a multimeter? You'd need a Megger or modern equivalent to really check line-earth insulation. And critically was the immersion heater behaving BEFORE you started messing with the wiring?
  7. flameport
    flameport
    10 Mar 2007
    8,783
    Thanks Received:
    1,659
    Poole, Dorset
    Country:
    To achieve what?
    Paying £200 for a device so you can get a tiny amount of 'free' hot water from solar panels makes no sense.
    That proves nothing - a LED light less than 7W won't trip a 30mA RCD, and even if it was more than that, the fault may be on another circuit and require far more than 30mA on the immersion circuit before it trips.
  8. Sponsored Links
Loading...
Share This Page
