thanks for the link it is conspiring against me as u tube freezes up at 11 seconds on any link lol
try placing 2 or 3 bottles or cans on a supermarket belt a few inches apart
now because off fluid dynamics they will collect a bit off energy but move very little as the only rolling resistance is the contents starting to rotate
and on the same token when you stop the belt the energy the contents amass will move the can a short distance
now whilst there is no fluid involved on a plane i think the energy transference[kinetic energy ]will be minimum in a similar amount as the air resistance will soon overcome the rolling friction off the bearings and tyre deflection
think off the rails under a train as a conveyor belt so if a train is traveling at 60mph imagine instead the rails are travelling backward at 60mph
now without any wind resistance the train on level track will travel around 10 miles before the friction overcome momentum
now in the instance off a plane you would have to apply the brakes to transfer enough energy to accelerate the plane on the belt in the same way you need to apply the brakes to stop the train "rolling " the wrong way
