Hi, I'm intending to install a new double socket in my bedroom, the socket is located about 2ft away from my 32amp ring main running under the bedroom floor, my plan is to install a junction box on the main and spur off and run it to the double socket. I have 2 questions though before I start..
I am a little unsure whether 2.5mm would be sufficient for the maximum throughput of a double socket so I have 6mm cable to run to the spur, is this ok or is it best to keep 2.5mm across the whole circuit?
The maximum size junction box I could find was 30amps, is this safe to use on my 32amp ring main?
thanks in advance
thanks in advance
