On an EIC, what would you put down as the wiring type for this FCU?
"Mixed"On an EIC, what would you put down as the wiring type for this FCU?
Shouldn't you have thought about that before you installed it?On an EIC, what would you put down as the wiring type for this FCU?
More education needed! Having been looking at this thread for 24 hours, it's just occurred to me that I'm not at all sure where on an IEC one has to record 'wiring type' - what's the answer?On an EIC, what would you put down as the wiring type for this FCU?
Nice job lining the faceplate screws up though.
Nah. The RH screw is a few minutes past 12.
What would you record as the wiring type for an FCU with T&E on one side and SWA on the other (either way around)?
Indeed. Mind you, although that is perhaps 'simpler', I'm not sure that the type of wiring on the load side is any less important!Which is why I suggested that the cable type recorded should be the one that feeds the FCU, not the load cable.What would you record as the wiring type for an FCU with T&E on one side and SWA on the other (either way around)?
Do you mean if the feed cable changed in type somewhere along its length? (about the only situation in which more than one feed cable would actual enter an accessory is on a ring, and it would then be almost unknown for there to be different 'types').Trouble does start, though, if you have a mixture of cable types on the feed. Then I would put an asterisk in and note that there is more than one cable type.
The programme I use does indeed ask for the cable type and installation reference method of each circuit including sub-main.Since no-one else has yet answered my question, perhaps you could explain to me where this information is to be recorded on an EIC?
