Hi, I'm hoping someone might be able to answer this question. We recently moved out of a housing association property and have just been informed that (although there had been no smell of gas 24 hours after we moved out on 20th August and we are sure we didn't knock anything) we are to be billed over £180 because:
"This is the information from our "Gas Safe" registered engineers report in bullet points:
1. The engineer attended the empty property on 31st August 2012 in order to carry out a void gas safety check. On entering he found a strong smell of gas.
2. A gas tightness test confirmed that there was an escape of gas on the installation pipe work.
3. The cooker point supply pipe, which was buried in the wall, was exposed and the gas leak was found on the cooker connection point and subsequently repaired.
4. Before each new occupancy, a gas safety check is carried out on the installation pipe work and gas appliances to ensure that they are safe to use and as such, the installation prior to the latest tenant moving in, was safe.
5. Whilst at the property, the neighbour called at the door to report a smell through the party wall in the few days prior to our visit.
6. Conclusion: The gas cooker connection point was knocked by the tenants cooker, be it gas or electric at the time of use, causing a buried joint to crack. This is confirmed because there was no gas leak above tolerance prior to the tenant taking occupancy, there was no reported smell of gas during occupancy, the neighbour could smell gas coming through the wall only after the property had been empty and at the gas safety check 3 days after the tenant moved out there was a strong smell of gas throughout the house."
We are sure this didn't happen, but it would be very helpful to have any suggestions about how else this leak may have occurred.
