Personally I agree with Noseall, but if you must do it your way then at least use sleeves to transfer the loading through the insulated render. Some heavy gauge steel tube may do if you use an anchor that relies on tightening to secure. If using a chemical anchor then you could use back nuts on the threaded rod to tighten against.
The objective is to be able to tighten up the fixings without crushing the insulation which it turn would crack the render.
Remember whatever your canopy weighs it will also be loaded up with snow, ice and winds at some point.
I understand now it may crack the render and squash the insulation. Trying to do a way that I best understand. What about cutting 2 small sections with grinder through the first render then cutting the insulation out. You would now be back to bare concrete. Cut 2 pieces of 4 inch timber and fix to wall with the 200mm expansion bolts. I would now have 2 pieces of timber flush with wall to fix my bracket to. But what bolts would be best to fix the brackets into timber. Maybe use 200mm expansion bolts which the first 100mm would be in timber then 100mm in bare concrete. This way I am tighting up against timber. Do you think this would work ?
