how to connect SALUS RT500RF and Vitopend 100
17 Oct 2012
Derby
hello,
I am having problems connecting Salus RT500RF and Viessmann Vitopend 100 WH1B
please look at photo
what is correct way connecting these things? :(
N goes to N
L goes to L
but it's not working :(
thanks for answers
cheers :D
cant see en enlarged inamge of the pic but sounds like you are just sending 230v power to the recivier you need to wire the switch wire into the boiler too
click in that thumb image and you will see bigger image
BTW, I am using NYM cable , 3 wires ( brown, blue and Yellow/green)
I connect blue to N, brown to L
and I don't know where to connect Yellow/green, it goes nowhere :( :(
this way nothing works =/
so what is wrong?
could someone how to connect ? where every wire must connect ?
:roll:
thanks
so what is wrong?
:roll:
thanks
why are you trying to connect this yourself when you clearly have no idea what you are doing?
Yellow/green is the earth wire and must not be used for anything else!
You need a three core heat resistant cable (or 3 core plus earth).
Brown to L, Blue to N at both ends (as your red lines)
Third colour to NO at Salus and 1 at boiler
Remove link between L and 1 at the boiler
Insert a link between L and COM at the Salus.
If your cable has an earth wire, connect it to the earth terminal of the boiler and make the other end safe in a terminal block.
thanks pal :D
everything works :D
I have the same situation: Salus 500RF and Viessmann Vitopend 100.
Unfortunately, the pictures are already removed from forum.
May I ask you to attach once again the wiring scheme?
Thank you
