Addng another pendant to 2 way switch
13 Oct 2012
Sheffield
Hi
I have a 2 way switch at the top and bottom of the stairwell that controls the upstairs lights but no light at the foot of the stairs.
I was hoping to add a new light downstairs by adding a junction box in the ceiling space (accessible) and joining the 3 core and earth along with the new wiring for the pendant in this.
I am not to clear on how I would connect the light into this junction box (where neutral and live would sit) and hoped you could point me in the right direction.
You cannot do it like that.
You need to run a cable from the old lamp to the new lamp and to connect new to same terminals as old
There will not be a neutral there.
thanks for the reply.
If I can't do it like that, any way I can come out of the switch instead. I really dont want to have to run a new cable down the stairs as I just replastered. Perhaps by using the neutral of the other switch downstairs?
No, you cannot do it from a switch (not possible).
There are no neutrals there. Study the diagram.
A wire can do anything we want it to do. They do not know what colour they are.
Sorry I meant from the neautral from the other switch (it is a 2 gang) - so neutral from switch 1 and live from switch 2
You will see that all wires are brown or sleeved brown.
Just because I's blue doesn't mean I's neutral. works better with black
Hello!!! Anybody home????
Look at the diagram.
There are NO NO NO neutrals of any sort in the switches in your house.
The place that you will find a neutral is in the light fitting itself.
Even if there were, you would be connecting the neutral downstairs to the live from upstairs. And this is a bad naughty and unforgiveable thing to do.
re
To fail to plan means that you plan to fail.
Sorry, not the answer you wanted, but that's the answer.
Hi
I understand that the sheath colour doesnt define the use of the cable, there is a third cable that is in the switch (the other gang) that from what I see goes to the outside light fixing, which is what I proposed using.
I do take the point about joining neutrals over multiple floors and mcbs isnt the best idea.
Was just trying to make sure I considered any possible options before biting the bullet and putting my crash helmet on before informing SWMBO
Thanks for taking the time to respond :)
Good. (provisional)
Don't you mean 'second'?
Oh, dear. Good withdrawn.
Why do you think that will be different?
It's not in the picture but does that blue not have a brown sleeve? - it should.
It is no longer allowed - is dangerous and causes RCDs to trip on both circuits.
That's where you're going wrong.
Look at these diagrams (yours is the bottom one)
You will see there are NO neutrals at any of the switches.
(Some houses are wired differently where there may be neutrals AT the switch position but NOT connected to them but yours isn't.
No, Third. 2 switch wires and 1 wire that passes through the backbox (joined by terminal strip) then on to the outside light, no brown sleeve on blue.
The second switch wire has a brown sleeve over the blue switched live, just the third cable that isnt visible as I could not get angle of the shot to show it in the low light.
Understood - Was just exploring ideas.
I say that to myself every day :)
Thanks, I understand that the blue wire is a switched live, will get chasing out tomorrow
