Looking for name of a specific type of bolt
15 Aug 2012
Yorkshire
I don't know if these exist, but what I'm looking for is a bolt that is tamper proof externally (completely rounded off), but internally, instead of a nut tightening the bolt, its another bolt tightening it - a bit like a male/female adapter I guess.
I assume these exist. Is there a formal name for them? Doesn't matter if the bolt isn't tamper proof as long as I can file/modilfy it so it is.
Combination of a 'sleeve bolt' on a 'coach bolt'?
Google terms for pics or description.
Sound similar to cabinet connector bolts.
Try a search for "connector bolts" I found some things that look like they might do the trick if they are large enough don't know if they do rounded heads but I expect someone does.
Regards,
footprints
How about a coach bolt, connected to another one courtesy of a connecting nut - Toolstation 86819?
Or am I missing something?
John :)
Perhaps if you can find one in steel, you could put a blob of silver solder in the slot/hex/pozi to prevent access, or just epoxy resin in any material depending on how critical the appearance is.
Glad you ID'd what you need, regards,
footprints
