Rubiks cube
  • Thread starter Thread starter EddieM
  • Start date Start date
it's only 18 moves from any combination.
What does this statement mean? :?
exactly what it says, from any of the combinations, you are only 18 moves max away from a solution.
That's not exactly what you said though :? However, given the speed of those who solve these little tinkers, it makes entire sense. Which begs the question as to whether a standard set of 18 movess will always work and indeed whether it is purely a routine of the intellect of the solver to identify and hence apply the correct algorithm.
Yes its a boundary limit, and yes of course it does. Seems very counter intuitive though.
Assuming your opening number of combinations is correct( :?: - can't be mithered to check), it is indeed a bit odd to be within 18 variants of one of the 6 norms.
if you google it, there are more sites telling you how to solve it than there are actual ways to solve it.
I used to be able to solve it, you need to learn 5 or 6 'moves' - not sure where i got my script from in the 80's, but it's now in a box in the loft....
what i find amaznig is someone devised a move that will swap over diagonals, and work without upsetting the rest of the cube.... amazing maths..
Ooh, vicious.
Here's one for ya - given there are 88 keys on a keyboard and given the limitations of a human hand, how many possible positions/chords/etc are there that a human hand can actually play?
What about the six fingered pianist.
Would that change the question???????
Just straight up or down finger placement there are 2^10 = 1024 combinations, and that's without considering tone/semitone distance placements. :shock: And that's every time a player places his/her hands down, which might be several times a second :shock:
