External Light From Indoor Switch
10 Dec 2008
Cheshire
I am trying to fit an external light adjacent to an indoor light switch to utility.
The utility is double switched - one by internal door and one by external door - hence its this switch I am trying to connect to.
The existing switch has 3 wires connected to Com L1 and L2
Reading up on here it would appear that there is no neutral?
Can I wire this up so it comes on with internal utility light instead using the wires I have?
Cheers
Only from the light position, yes, but then - with neutral, you would be able to wire it however you want.
Cheers for reply
But there is no way I can do it from the switch?
Obviously the wires at the light itself cant be accessed very easily.
If there is a neutral at the switch, it is normally in a connector block tucked in the back box. It won't be connected directly to the switch.
You will probably have to consider getting the neutral from another part of the same lighting circuit.
Alternatively, get the live AND neutral AND earth from another circuit, perhaps from a socket circuit via a fused spur unit.
Yeah deffinately no neutral.
There is a socket below the utility units - I will take the feed from that - means taking some tiles off to run cable but hey.
Link not working Martin. The light is at back of the house and just allows us to put stuff in the bin at night :-)
If you come from the socket, be sure to get the live from there as well as the neutral. Same with the earth.
You say this socket is below some utility units. Be certain the socket is not controlled by a local isolator switch - as some sockets for appliances can be for ease of isolation.
