I need to cut out the sink hole in a length of high-gloss finish work surface, or counter-top, and am hoping someone can give me some tips as to the best tool to use to make this a clean and easy job.
I have had to do this same job a couple of times over the years, and previously used a jigsaw, but found this method to be inaccurate, as the jigsaw tends to wander very easily and can make the cut uneven. Perhaps I used the wrong type of blade? I seem to recall that I ended up trying to clean up the finished cut out with a file, so it was a good job that I cut the hole quite a bit on the small size. Also, whether using jigsaw or handsaw, cutting from underneath or from the top, the shiny surface of the board is easy to splinter.
Is there a better way?
I have read that using a plunge router is preferred by some, although I do not own one, or have any knowledge of using one. Also, I have read that using the jigsaw with a down-cutting blade can also work. Is this true? I have looked for downward-cutting jig saw blades and cannot find any. Are they known by a particular name other than 'downward cutting jigsaw blade'?
When it comes to routers, are the inexpensive jobs sold below £30 any good, or just not up to the job? Thing is, I don't want to spend loads on a tool that I may rarely use. Okay, so I could hire one for a day or two, but this might cost as much as buying?
Any advice gratefully received.
