I want to replace a warm air heating system and a separate water heater with a combi boiler and radiators in my flat. It has a parquet floor on a concrete subfloor so routing the pipes round the flat under the floor is out of the question.
It would be easy enough to feed the pipes near to the ceiling but I am not sure about feeding the pipes in to the combi and radiators as these are normally fed from the bottom.
I think there are combis available that can be fed either from the bottom or the top (correct me if I am wrong) but what about the rads? Will I have to route both pipes to the bottom? I will be using vertical rads in every room so I am not sure how good this will look.
Are there any rads that have built in pipes bringing the feeds from the top to the bottom?
thanks for any advice,
D
D
