Hey Guys
I am thinking about having some fluorescent under-cupboard link lights installed around my kitchen, but need a bit of advice as the cupboards are a bit spread out.
What is the maximum length of 0.75mm 2-core that can be used?
If you look at the diagram below, you can see the lower-right cupboard is approx 7 metres away from the power supply (only one available) when taking into account the drop from ceiling.
Click Image To Enlarge
Also, is it OK to run 0.75mm 2-core through the void behind 100mm plaster ceiling coving?
