Maximum Length Flex For T5 Link Lights
This could mean you will have three plugs for one double socket.
Can you replace the double socket for a triple socket?
Triple sockets aren't available in fancy designs, just plain white plastic.
Or, you can fit a junction box near the supply end of the cupboard light wiring, so only one three pin plug is needed for the lights.
You would need a junction box with cable clamps to secure the flex, or plenty of cable clips.
Could a junction box be used AFTER first light (top-left in Overhead Diagram), giving two outlets?
One cable/outlet could feed the two 'linked' lights (top-right).
A separate cable/outlet could feed the furthest light at bottom-right?
All lights would then presumably come on when the switch on the first light is pressed?
Alternatively could these lights still be linked together (despite the distances), using T5 Male/Female Rewireable Plugs like the ones below and correct cable?
The longest pre-made cables I have found are 3 metres.
If none of the above is acceptable, I'll look out for one of those 3G sockets when in town tomorrow.
The fusing of this is getting a bit silly:
16A MCB to 13A fuse in socket outlet to 3A fuses in lighting & hood plugs....
Unless the lighting and the hood come with plugs already attached:
Just put a 6A breaker in the CU.
Forget 3 pin sockets, plugs and 1362 fuses......
Just use DP switches to isolate.
Bugger it!
I'm just gonna plug the cooker hood into an existing 3-pin socket with 3 amp fuse. That will be OK I assume?
This will mean extending the cooker hood cable by a metre or so, losing a wall socket and stop the cooker hood and lights being on their own circuit.
But it will save a lot of hassle and confusion.
Thanks for the advice guys.
As usual, much appreciated.
