Hi all,
What level would you run cables in a newly vaulted ceiling? The timbers are 200x50, celotex will be going upto 140 with 20mm below the rafters.
Would you run the cables above insulation, in the middle or below the rafters between the 20mm insulation and bottom of the rafters?
Im just running the cables will have a Part P Spark to connect and test.
Thanks in advance
Paul
Thanks in advance
Paul
