Hi, I have a Worcester 24i RSF combi boiler. Now the problem I have with the boiler is that I believe the expansion vessel has failed.
I have tried replacing the PRV to no effect and now the pressure rises too much when the heating is on (up to 3bar) and drops to zero when the heating is off. I have tried pressing the valve on top of the expansion vessel and water does squirt out.
Now I have seen some very informative guides on here about replacing the vessel with an external one, which normally place the vessel on the return feed but I have a few questions...
1) There is a pipe that comes from the pump and up to the expansion vessel. Can I simply cut this pipe and re-plump it to an external vessel underneath the boiler or is it better to leave the old one in situ and plumb it into the return. I can access this pipe quite easily and it seems easier for me to just re-pipe it from the pump.
2) does it matter which way up the expansion vessel goes?
Many thanks.
Rob.
Many thanks.
Rob.
