Hi All,
I’m embarking on a project to install a new bathroom/toilet suite. Now the current floor can be described as rotten at the moment. Some of the joists will need to be replaced and a new flooring installed together with new tiling. The bathroom is suffering from true dry rot on (flooring, joists, bearer plates skirting board and masonry). During the inspection, it was decided by a DPC company that some parts of the bathroom will have the existing plaster hacked off, a anti fungal chemical injected, left to dry for a few weeks and then the walls re-plastered. They also said that new joists will be fitted with pre-treated wood. They also said that the wood will be isolated from the wall plate/brick pier/brickwork using a physical damp proof membrane.
The question that I have here is that, the charges for the DPC company are a bit on the high side, a mate of mine told me that the chemical DPC can bought and a machine to inject the chemical into the wall rented as well. He also suggested that a builder can do all of this.
My question is that where can one buy the chemical from and what is the name of the machine that injects the chemical into the wall and where can it be hired from?
This is for the bathroom/toilet. Secondly there is a requirement for a vertical 1.5 metre high DPC chemical course on the ground floor living room space also. I understand that the chemical takes a few weeks to dry out, is it possible to get one which doesn’t take a long time to dry out. Does anyone know what DPC course I can buy to get my builder to carry out the works.
Any info or help will be most appreciated.
View media item 60822
