Hi All,
I’m embarking on a project to install a new bathroom/toilet suite. Now the current floor can be described as rotten at the moment. Some of the joists will need to be replaced and a new flooring installed together with new tiling. The bathroom is suffering from true dry rot on (flooring, joists, bearer plates skirting board and masonry). During the inspection, it was decided by a DPC company that some parts of the bathroom will have the existing plaster hacked off, a anti fungal chemical injected, left to dry for a few weeks and then the walls re-plastered. They also said that new joists will be fitted with pre-treated wood. They also said that the wood will be isolated from the wall plate/brick pier/brickwork using a physical damp proof membrane.
The question that I have here is that, the charges for the DPC company are a bit on the high side, a mate of mine told me that the chemical DPC can bought and a machine to inject the chemical into the wall rented as well. He also suggested that a builder can do all of this.
My question is that where can one buy the chemical from and what is the name of the machine that injects the chemical into the wall and where can it be hired from?
This is for the bathroom/toilet. Secondly there is a requirement for a vertical 1.5 metre high DPC chemical course on the ground floor living room space also. I understand that the chemical takes a few weeks to dry out, is it possible to get one which doesn’t take a long time to dry out. Does anyone know what DPC course I can buy to get my builder to carry out the works.
Any info or help will be most appreciated.
There are a couple of obvious questions to ask, the first and most obvious being, is it a ground floor bathroom? If not then I don't really understand all the talk of chemical DPC's. that being said I don't understand why you would use it anyway.
Lets discuss the dry rot first. There have been many chemical treatments recommended for dry rot but you simply don't need them and even if you did, Boron isn't one of them, Boron is more often specified as a woodworm treatment and I've found no mention of this in your thread.
Best practice treatment for dry rot is to simply, eradicate the source of moisture, introduce rapid drying and increase ventilation. Keep timber moisture content below 20% and you won't have a problem with dry rot, simple as that.
In terms of the damage done to existing timbers then yes, of course these will need replacing at least one meter back from the last sign of infection. The serpula Lacrymans fungus feeds on the lignin (part of the cellulose) within the wood and this is what causes the wood to crumble and lose its strength. Obviously use pressure treated timbers and if building into the brickwork you simply wrap the joint end in a plastic boot made from a roll of DPC and a staple gun. Alternatively simply place the timbers on joist hangers.
Do not waste your time or money on chemical DPC injection, if the plaster is defective then replace with a renovating plaster such as limelite but DPC injection is not necessary.
Critical to all recommendations is an understanding as to where the bathroom is. I've assumed ground floor, obviously with timber floor and sub floor void. If you have dry rot then sub floor moisture content is high and you will continue to have problems until you deal with the problem at source rather than considering management solutions like chemical treatments etc.
Remember... Eradicate the source of moisture.! Is there a leak under the floor or is it caused purely from ground moisture? If no leaks then fine, you simply have an issue with poor sub floor ventilation. Inspect your air bricks. Have you got enough or do you need to install more? I have to say that the advice given by pinenot is complete nonsense and shows a very poor understanding of these issues. Particularly his advice to 'Hack out affected brickwork', as I said, complete tosh!
The bathroom/toilet is on the first floor and not groundfloor.
What are your thoughts on the dehumudifier, and where can I find a meter to measure this ? Any good place you can recomend to rent a industrial strength dehumidifier ?
The hacking off the plasterwork is what was written in the damp and timber report carried out on the house. I guess these are areas previously affected by damp.
