I have a masthead amplifier on the TV aerial that is fed in the normal way via a PSU and coax cable from behind one of the TV's. Next week I am having new windows installed and the "powerback" coax cable which goes through the old window frame will be the devil's own job to remove unharmed.
So could I simply cut the coax cable near the PSU fit a male connector and rejoin it to the old cable routed in behind the new window frame, with a male connector fitted and join via a simple female connector ?
Or will it be "live" ! Are there any connectors designed for this purpose ?
What other options would you suggest ?
Thanks John
Thanks John
