Can a boiler flue have 2 90o bends & run downwards?
Speaking of blocking, this may also be a legal issue and so she may be compelled to make whatever modifications are necessary.
Over here this would fall under Landlord/Tenant Law.
If it's in a stairwell and partially blocking access to your flat I would call the local authority and get a building inspector out to have a look especially if it's your route out of the building if there's a fire. Was there a boiler there before?
im a little bit confused as to whats blocking what and how
Me too. Maybe I'm too cynical but sounds like a DIY job.
Why is the backing board higher than boiler and maybe I'm wrong but is the spur upside down?
Surely coring new hole is easiest way to fix, although it certainly doesn't look like 1m from window as prev said.
surely stair well is a communal space owned by the freeholder? how on earth would that be allowed? Im sure there must be more to this story.
There usually is far more to these stories.
Simply a flue for a condensing boiler must slope UPWARDS away from the boiler!
The flue must terminate outside at least 300 from any window reveal ( unless a flue diverter has been fitted. ).
Tony
I'd be interested to see some more pics ie side view from the stairs etc
If that is on a stairwell then its never going to look right if it is a communal staircase then I seriously doubt the legality of it being there anyway
Matt
Yeah there was, but it was smaller & higher. I heard her tell the engineer when he suggested it goes higher 'No, it needs to be at a height I can reach.' It's definitely a safety issue.
It doesn't show in the photo but the boiler is low and jutting out 65% into the stairwell. Anyone tall will bang their head on it & it will be impossible to move heavy domestic furniture past it.
Surely coring new hole is easiest way to fix, although it certainly doesn't look like 1m from window as prev said.[/quote]
The backing board is where the old boiler was. She has had it brought lower & this boiler is wider than her old one. It juts out into the stairwell 65%. Anyone tall will bang their head & moving large domestic furniture past it will be impossible. The 1 meter was distance from wall to window, the flue is about half a meter. We asked to have the hole moved higher but she refused.
She is the freeholder - thats why she thinks she can do whatever she wants & finds it objectionable that we question it. I heard her tell the engineer when he suggested it be higher 'No, it needs to be at a height I can reach.' She use a step stool to reach the controls.
Tony
She is the freeholder - thats why she thinks she can do whatever she wants. So the flue needs to be 300cm or inches from the window reveal? Just measured it - the flue is 40cm from the window frame. Good to know it must slope upwards too.
so are you a tenant or a leaseholder? I think as someone suggested earlier it could contravene fire regs. A visit from building control may be interesting...
Matt
Definitely doesn't look right but she's the freeholder so she thinks she can do what she wants.
