Anyone used one of these , are they any good for a Temporary/Permanent repair ?
I Have seen a similar type "Clip on" looked a bit gimmicky and large.
Got called out to a burst pipe over the weekend, Water Board had been, turned mains off in Pathway and left occupier with a couple of bottles of water and said " its now your problem", despite the leak being the other side of the water meter.
I would normally use a slip lock coupling, but the leak (Pinhole) was in 1/2 inch black poly pipe circa 1972, Plumbers merchants do not stock the 3/4 inch exterior fitting compression joints and liners, and even ordering one would take a week or more,( thank goodness the occupiers have good neighbours to supply them with water).
To cut the pipe and put on a compression fitting is going to be a problem because pipe runs in channel in concrete floor, (I reckon the pinhole leak is original and been leaking into footings since it was installed)
I saw this fitting on the "net" and thought this might work,
Dont think the customer can afford total replacement of the poly pipe back to the stopcock. (And it looks like it could be a 5 minute job to fix it. when it arrives.)
