Can anyone advise me please. My house was built about 15 years ago onto the end of a terrace of 4 story Victorian houses in a similar style. I'm having a box recess built into my shower area which is on the top floor, effectively the roof area (like a loft conversion). The whole house is more or less steel framed. There are 2 steels running from one side of the house to the other (in the roof area) and then a beam of some description ontop, across each end- fairly conventional structure. The recess measures 500mm x 300mm and has been cut almost directly below one of the side steels. The wall is made of some kind of blockwork, (Thermalite?) easily sawable with a wood saw. The joists run parallel to this wall. When the installer took the block out, we could see the cavity and then my neighbours original outside wall. So the wall in question is effectively the inside skim. My question is, is this safe to do this without any sort of lintel? From an untrained eye, it would appear that the integrity of the wall has been compromised- especially with that steel above! We don't know how the steel is supported- would they have gone into next doors wall (i.e. the party wall) with the steels? If this wall in which the recess has been cut is supporting the beams, can it have been built of such soft blockwork? Any answers would be much appreciated and maybe I can then sleep at night!!
