Those fused isolator are generally used in industrial and commercial environments, there's nothing stopping one being used in domestic. They have a hole for a proper padlock for locking out for isolation, they also have a visible air gap when the forks are opened inside.
Fuses are more reliable than circuit breakers as a circuit breaker is a mechanical device. It is fairly easy to design systems with fuses an provide discrimination as their energy let through's are a fair chunk lower than circuit breakers, a fuse will disconnect quicker where the fault current is higher whereas a circuit breaker still takes time to open.
Then there is the cost of a fuse over a circuit breaker, a 100A fuse as found in a switch fuse is around £5, a circuit breaker is many times this price.
They are also used where the Short-Circuit Fault Current is too high for a breaker to safely handle.
High SC Fault Currents are likely to be present in commercial and industrial environments, less likely in a typical 100amp single phase household supply.
They are also used where the Short-Circuit Fault Current is too high for a breaker to safely handle. High SC Fault Currents are likely to be present in commercial and industrial environments, less likely in a typical 100amp single phase household supply.
