We're starting to strip our mums kitchen in prep for fitting a new one. When I removed the induction hob I noticed that it was fed directly from the rear of the plug socket that was designated for her cooker. The socket is fed with 6mm cable direct to a cooker switch above the worktop.
I'm just wondering if this is the correct way to do things i.e. is it safe to have a 7KW~ load fed from the back of a normal plug socket (admittedly the socket being fed from a 40a mcb w/ 6mm cable seems good, but are the terminals of a plug socket designed to have the hob wired in too?).
While I'm here I have another question you may be able to answer! Our mum is having integrated appliances and I've read that you can either have a socket behind the appliance controlled via a DP switch above the worktop, OR you can have sockets that remain accessible for example you can 'hide' the sockets at the back of a cupboard where you're still able to get to them. For aesthetic reasons I'd prefer the latter option and so I was thinking you could run a 2.5mm radial from the 'ring main' socket (above the worktop) to behind one of the new cupboards and put a double socket there. Obviously we'd leave the a large hole in the back of the cupboard for access to the socket/appliance plugs.
They say a picture paints a thousand words...
Any help is appreciated!
