I am trying hard to get an empty 4-way garage distribution box, without success. Everyone - including TLC, Screwfix etc - now sell only complete units. I have the RCD and MCBs, so why duplicate what I don't need? Does nobody sell just the boxes any more?
Simple - the house wiring had to be extended into an extension, which required a larger consumer unit, so the electricians preferred to supply one complete with new fittings.
So you're going to take the MCBs and RCD from the old CU, and put them in a new enclosure?
Why not use the enclosure you already have?
How is the garage supplied? Who installed the cable to it?
Do you know what tests you would carry out on the garage installation - what sequence you'd do them in and at what point you would energise it, and for each test do you know what is being measured, why it is important, how you would carry out the test, and with what equipment, and what sort of results you would expect to get if everything was OK?
What will you tell the council will be the way you'll ensure your work complies with Part P?
The existing box won't be used because it is much too large for the job, and of course has no IP rating. I will therefore be using the most appropriate box for the job - a 4-way IP44 rated garage unit.
The electricians will be checking the installation for me before they leave but, even though it's run in 4mm Arctic cable in conduit, it will continue to be a plug-in extension. I just want to be more confident of its safety than the average shed extension, and I'm sure you know what I mean.
I agree with you over those flimsy constructions which take the name of sheds. Mine was designed as an outside office - well built and insulated - and I wouldn't be without it.
You'd be better off using your time and money to fix the leaks in your outbuilding. Are you planning to use IP44 rated lights and sockets and switches?
