How come?I have the RCD and MCBs,
Depends on their provenance, and what you plan to do with them.so why duplicate what I don't need?
The electricians will be checking the installation for me before they leave but, even though it's run in 4mm Arctic cable in conduit, it will continue to be a plug-in extension. I just want to be more confident of its safety than the average shed extension, and I'm sure you know what I mean.
You'd be better off using your time and money to fix the leaks in your outbuilding. Are you planning to use IP44 rated lights and sockets and switches?The existing box won't be used because it is much too large for the job, and of course has no IP rating. I will therefore be using the most appropriate box for the job - a 4-way IP44 rated garage unit.
Do they know this? Are they going to issue an EIC for it? Are they going to tell the council that they designed and installed it?The electricians will be checking the installation for me before they leave but,
What?even though it's run in 4mm Arctic cable in conduit, it will continue to be a plug-in extension.
I know what you think you mean, but I'm curious to know why you think this CU will enhance safety.I just want to be more confident of its safety than the average shed extension, and I'm sure you know what I mean.
