Definately not a DIY lash up, but I suppose it could have been done by a previous sparks. The CU looked about 15 or so years old, so maybe at the same time as this, but without actually testing that the earth was any good.
I know when I started out in this industry, testing was for fault finding!!
Definately not a DIY lash up, but I suppose it could have been done by a previous sparks. The CU looked about 15 or so years old, so maybe at the same time as this, but without actually testing that the earth was any good.!
From the way Mr DNO was talking, the network has never been earthed, rather than a fault on it. It might be an earth supplied from the water or gas before they were changed for plastic pipes job.
Interesting. I would have thought that if it were a metal-sheathed cable, even a DNO would feel obliged to earth that sheath. From what you say, I guess not!
You must have a much better memory than I do! Mind you, an eon is an awfully long time to expect anyone to remember something (and even I am not quite that old)
