Hello, hope someone can help.
I am about to start wiring a loft extension, hopefully I will find an electrician that is happy for me to lay the wires, with him making the final test and connection.
In the loft I have a bathroom and living area, can 1 RCD cover both these areas, or do I need 2 circuits for each, each with 30mA protection ?
As the new circuit/s are RCD protected, a 12v bathroom extractor fan in Zone 1 is acceptable?
I am going to install 2.5 T&E for the lighting circuits - in case it runs through any insulation, is that a correct method where the cabling encounters insulation (100mm PIR)
I will also run cable to these along the 150mm safe zone (NICEIC safe zone diagram) at the top of the wall behind battened 12.5mm plasterboard, as all new wiring is RCD protected, I assume that will be OK?
