- Joined
- 4 Jan 2012
- Messages
- 354
- Reaction score
- 7
- Country
Hi guys
We've got a slight leak on a cold feed which initially came from a pin hole leak. Couldn't get anything around or cut the pin hole leak pipe so had to cut it further up and put some plastic pipe in.
This is fine but with the original pipe work (which is the old size copper) connecting to 15mm coupler's at either side - there is a slight dripping leak. Can I buy a coupler which is the old size on one side and 15mm on the other side? Found this on screwfix but wasn't sure if its the one (Im not a plumber just a keen enthusiast)
http://www.screwfix.com/p/female-coupler-15mm-x/93992#
Thanks!
Thanks!
