I am running in my new central heating pipes under the floor in my cottage. I have opted for plastic as I can do the two flow and return long runs in one go. 25m each, it is a very long cottage, I plan to tee off at each room in 15mm from these main 22mm pipe.
Now having not worked with plastic before. There seems to be a massive choice of types and makes of connectors, I don't want to be able to discount again, as I see some of them let you do this. For me I want want reliable connections as they will be under floor.
Ant suggestions?
A friend said I should use compression standard tee's with the inserts.
Cheers
Ant suggestions?
Cheers
