Makita HR2450 hammer drill repair??
2 Jun 2005
West Midlands
Has anyone out there knowledge of repairing these hammer drills.
Mine is hammering fine but the rotation sticks when the going gets tough !
Any ideas on repair and if it is worth doing?
I can honestly say that I have never had a grinder or sds drill repaired.
We work them to death then buy new ones. :shock:
You have to weigh up the age of the drill, the cost of the repairs v's buying a new one. We just give ours a decent funeral then buy a new one.
More expensive items do get repaired but are also replaced with new ones and the repaired fella then becomes a spare.
It all depends on your tool usage.
Have changed the motor brushes on mine, if it's old they may be worn.
thanks for that but I guess that if the hammer is ok the motor must be as that droves both functions.
I think Noseall has probably got it right when he says 'works em to death' . I must admit. I do like messing with them and the odd gear is only a few bob so sometimes it is worth having a look.
Just racking the remaining brain cell.....these drills have a cam clutch which revolves on a cam shaft and the parts wear as a pair - I'm about certain that will be the problem but as for parts availability I've no idea, unfortunately.
John :)
John :)
thanks John, I can see what you are talking about from repair manual.......can get them for £15ish so probably worth a go.
