have a new plug in flow meter so checked the input off most off my led bulbs
the findings on some was quite surprising
now the ones with aluminium castings are fairly close to rated values although this could be pure coincidence
and when you have the same bulbs the higher input watts tends to mean higher output but not always
heres my findings not scientific but interesting
2x1.2rated2=1.7w
4x 2.5rated 1=2.9 2=2.1 and 1=1.6w
4x4w rated 1=2.3 and 3= 1.5w
4x4w rated 1=4.4 and 3= 4.2w[metal]
1x7w rated [toolstation]=6.8w[metal]
3x7w rated 1=6.1 and 2=6.3w[metal]
3x10w rated 1=8.1 1=8.3 1=8.8w[metal
now apart from the toolstation at 240v all the rest [metal] are 100-240v so seems you have compromises in efficiency to cover a large voltage range as the 4w at 1.5w are nearly if not as bright as the metal ones at 4+w
so from my list the 1.2and 2.5w bulbs [line one and two]are not as good as the 4w [line 3]running at 1.5w giving out around 50-80% more light per watt
2x1.2rated2=1.7w
