Gate Bolt
7 Feb 2014
I need some help with a gate bolt. I have a gate which is metal framed but with wooden slats. The gate is held to the metal posts by two bolts, one at the top and one at the bottom creating two hinges. The problem is, as you open and close the gate it slowly undoes the nut at the bottom. As the nut loosens the gate begins to drop until after a week or two of use it has dropped so low the gate won't shut.
Tighten the bolts hard doesn't seem to help, and loosening them off didn't solve the problem either. I wondered whether a washer above the nut and below the bolt head would solve the problem?
Any other suggestions gratefully received
Richard
Second nut tightened against the first to lock them standard engineering practice.
Should sort it once and for all :D
That would work, except the bolt isn't long enough. I may have to look at replacing with longer bolts if that's the best fix.
Cheers
Richard
Buy a bottle of loctite threadlocker, smear it on the thread then tighten the bolt. You can still undo the bolt with a little force but it wont work itself loose.
