I replaced my hot water cylinder at the weekend, it is an indirect cylinder. The indirect feed and return are 28mm pipe to 1" connections, the upper hot pipe has a bleed vent which you unscrew to remove air, the lower pipe does not. Apart from that it has an immersion heater, cold feed at the bottom & hot out at the top.
The system is connected to a Ideal Mexico RS80 boiler, the rads which are working OK are pumped, but the 28mm feed and return to the cylinder are gravity fed.
The system is very simple and old, not tank stat, just a pipe in and a pipe out.
So the rads work OK and I have bled the air. I bled the upper indirect connection to the cylinder & the hot water from the boiler gets this far, but it does not appear to enter the cylinder as the water & bottom return are cold.
I am thinking that it is an airlock, but does anyone have any ideas what the problem could be and how to solve it.
Many thanks Nick
Many thanks Nick
