Hello just after some advice regarding a socket near the CU in the hallway.
Im going to be moving my network equipment into the under stairs cupboard where the CU is located.
I want to add a double socket to power the equipment which will just be a modem and a network switch and perhaps a few items such as an av amplifier and sonos equipment which wont draw too much power.
I already have an empty space where old electric heaters were installed I plan to re-use the MCB which I think is a 20a ( I will double check)
What would be the best way in doing this? Can I come off the tails of the existing sockets and surface mount the cable to the double socket?
I would like to re-use the wiring that comes off the 20a to change it to a double socket - The wiring is 2.5mm t&e and I need to check if it supplied all 3 heaters. I will take some pictures to help verify.
I am aware adding a 20a will be notifiable under part p is that correct?
I have been quoted £60 for this to be installed and a test cert but I am wondering if at all possible I could do it myself?
Just asking what is involved in doing so.
EDIT: Its actually a 32a MCB that was pulled and disconnected from the CU would that mean he wired the heaters on a ring?
