I would like to build a patio that would be at the same height as the internal floor. So that as you go out through some french doors the patio is at the same level. This will be above the DPC, hence my plan is as follows:
* Patio will slope away from house
* Linear drain between patio and house.
* Balck Ubiflex flashing 200mm high on the brick work to prevent water from splashing on to the brick.
Any thoughts?
Any thoughts?
